Just wondering if I should bleed my Magura master or the caliper first? I'm guessing caliper first cos its the furthest point?
Oh, and where's the cheapest place to get pads?
if you just put the master, line, and caliper together and filled it with fluid i'd probably just give the master just a quick bleed first. This is just to prevent forcing air bubbles down the line. Then bleed at the caliper until you're satisfied, then give the master another quick bleed. Don't forget to make sure the master is the highest point during the bleed and also tap the line regularly during the bleed to help shake bubble loose.:thumbup:
