1 - 8 of 8 Posts
Looks good id suggest keeping the side bars around longer as it wasnt up long enough. Found myself rewinding several times to read the items.
Not bad, now put some gear on and bring it further back so you don't run out of gear / motor. :D
You should never "hover over the rear brake" you should use the rear brake often weather you need to or not. Just covering the brake doesn't teach you the instinct needed to save a wheelie gone bad.
Good video, its hard to explain all that while trying to watch your hands....
Also you are the only other person I've seen clutch gear shift mid wheelie.... :thumbup:
yes, i can't agree with that enough. the actual feel of the motorcycle is the most important thing over all. someone simply trying to explain it to you is very tough, i just figured i'd go over a few things haha
the handbrake is a setup for the rear and it's a single caliper.
1 - 8 of 8 Posts
