1 - 20 of 94 Posts
So a couple of people I've seen here have some sweet 100's, so how about everybody posts up some pics of their 100 and list their mods to give the rest of us some inspiration.
Here you go. It's for sale if anyone is asking...
2002 XR100R
Black Powder Coated Frame
TK Race Products Works Shock Brace
TK Race Products Engine Hangers
TK Race Products XR/KX Conversion Steering Stem
2 Sets of Tapered Bearings Steering Stem Bearings
Banke Frame Brace
BBR Swing-arm (Powder Coated Black)
Stock Swing-arm (Powder Coated Black)
New Works Shock with Spring (3 races on it)
BBR Heavy Duty Shock Spring
Leo Vince Carbon Fiber/Titanium Exhaust
K&N Air Filter
2.50” x 17” Excel Wheels with Dunlop Racing Slicks (3 Races and 1 Practice Day on New Rubber)
Yoshimura TRS Exhaust
2006 Kawasaki KX85 Front End – Valved and Sprung by Race Tech for a 200 Pound Rider (3 Races)
280mm Oversized EBC Rotor and Relocator Bracket
Jetted
14T and 15T Front Sprocket
48 and 50 (Sprocket Specialist – Aluminum) Tooth Rear Sprockets
Tag Mini Play Bars
Cycra Pro-Bend Bark Busters with Stealth Handshields and Barends
Fresh Top End – Piston, Rings and Cylinder Honed with 1 Race on Top End
Stock Front Forks with BBR Heavy Spring
Stock Airbox
Discussion Starter #4 (Edited)
It's not much yet, but here's mine. Hopefully when the rest of you guys post yours up I'll get some ideas. It's currently stock other than the tires, but will very soon be getting BBR shock and fork springs, Banke frame brace and BBR 120 kit.
The mods include BBR pipe, frame cradle, and chain guide all black. Black Excel wheel, Dunlop KR 133 and KR 149(125 GP tires), Versah H-D clutch springs, XR80 forks with 100 springs, 24mm carb, no airbox, Pro Taper bars, Emgo barkbusters, 15T countershaft sproket, K&N air filter, Works Performance shock is in my room, and all black plastic. I hope to buy a set of K Factory Engine Hangers in tha future.
Discussion Starter #7
What do the xr100 springs in xr80 forks do?
You've got to purchase an aftermarket steering stem to do the conversion. TK Race products makes a kit that includes the steering stem and tapered bearings needed to do the conversion. I actually have a buddy that has a brand new KX front end with the steering stem already pressed for sale if you know of anyone that is interested.
XR100 fork / wheel upgrade.
I put a set of Honda CR80 front forks and aluminum wheels on my XR80. The same modification can be used on an XR100. It's an inexpensive way to make a major improvement in suspension. With it you get aluminum wheels and a front disc brake. It's a bolt-up with only minor modifications necessary. You need to modify your headset to accept the CR80 cone bearings and you will need to weld a small tab on your frame for the floating rear brake hub arm. I'll take some pictures this weekend and post so you can see what I'm talking about. I've got a complete extra set-up in the garage that I might want to move on. I'm in So. Cal.
Jim
XR100/CR80 wheels - fork - disc front brake conversion
The CR80 set-up I used and have an extra of is off a 1986 CR80. That's a front disc and rear drum. I think it would be quite an undertaking to convert the rear to accept the a disc brake without a complete swingarm modification. The great thing about what I did was it is inexpensive, easy and really make a dramatic difference in performance and appearance.
Oklahoma Super Bikers XR 80
Here is a pic of the bike that i raced and won the F2 Novice Championship on in the Oklahoma Super Bikers 08 Season.
It's a 05 CRF 80 on 12's. Please excuse the ad on the bottom of the pictures , its the only pics i had.
XR80 / CR80 Modification
I have pictures to share but can't seem to attach them to this thread. Anyone have a suggestion on how it works?
Jim
2003 XR100R
Stock Motor
17"x2.50" fr w/bridgestone soft 90/580
17"x2.75" rr w/dunlop soft 115/70
420 chain conversion
Works Shock w/BBR spring, TK Racing resivoir mount
RSW front fork brace
1 bbr heavy front spring/ 1 stock spring. Heavy fork oil
EO Outlaw pipe
Banke frame brace
TK Racing engine brackets
Jetted stock carb w/K&N Filter
Tag miniplay bars
Cycra Probend w/Stealth covers
1 - 20 of 94 Posts
