Hey guys - looking to mod my air box - I'm going to use the K&N RX-5179 filter (same as EVO2 kit I'm told). I do not want to lose any low end/mid range power - Mid range will be most important to me.
Stock bike - But keep in mind I will have Canisterectomy/SAS valve removed, and adding a FMF Powercore 4 slip on with insert removed. I will have it dyno tuned with TUNE-ECU.
Ideally I want to use as little space as needed to get the results - so that I can use the rest of the removed airbox space for either storage or a customized aluminum extra fuel tank.
Let's get some ideas going!
Discussion Starter #2
Nevermind the original - the best thing to do is to take out your stock rubber Velocity stack and use a K&N RU -0830.
THOR450 did it first -and he did a damn good job. I'll be doing it myself as soon as the filter is in.
