Can't find torque specs for the cs sprocket "NUT".I've read it's 44 ft. lbs.,but wanted to make sure.That nut is so light,I don't want to strip it out and have to wait for another.
thnx Stv.
Counter shaft "nut" 60Nm w/ loctite 243
The bolts are different, so to be clear, we are talking about the 25-26mm aluminum nut with the locking tab that goes behind it?
I have the torque spec value for the engine and chassis copied and saved under my desk blotter. :D
44ft/lbs is correct.
nut specs
YES, I am talking about the nut,all other sites I've gone to deal with the bolt,like the SXC's have.Thank you very much.Stv
Did you put a fresh o-ring on behind the removable countershaft spacer. They tend to leak oil after a couple of sprocket torque cycles. Just a heads up:D
