Hello,
I have a KTM 525 EXC 2005 motard and want to run enduro. I have looked at some rims from a KTM 250 SXF 2014.
Will they fit on my 525 EXC? Front wheel is 80-100-21 and rear wheel is 100-90-19.
Thanks for the help
Are you able to measure the bearing/axle size of each wheel? I also have a 2005 KTM 525 EXC and the front axle is 26mm and the rear is 20mm.
Read Only
If they are genuine KTM wheels, I'm pretty sure they will fit, but will require different "spacers" due different axle size. (Aftermarket are an unknown, and often use different spacers...)
The rear tire width is a little small, as might be the rim width. (Because they are off a smaller engined bike.)
The 19" size is favoured for MX, less suited to Off Road. Still, a personal preference.
I'd keep looking for correctly sized wheels (rear) suit your 525. (Anything from a 450/500. KTM from '04- around '12 should have correct axle size)
