21 - 34 of 34 Posts
Awesome job! I want one of those! Lol. You are very impressive to complete such a project.
Discussion Starter #24
with a 2016 SX 450, I could try to build a nice "690 engine" project.... around the 100 kilos
I will think about that :hmmm:
Discussion Starter #25
finishing the exaust pipe:
My pipe exhaust protection (316 steel stainless, 1.5mm thick)
the relay bracket plate
concerning the pipe between the air box and the throttle body:
WELL DONE SIR!:clap
Totally amazing fabrication work Fab, can't believe that you got the big 690 donk to fit and make it look so nice and professionally finished. :clap:
Have you already installed the bottom frame piece, and are you still able to remove the engine with it in place? Can you remove the valve cover in place or does the engine have to come out for valve adjustments?
Cheers,
Lukas
Discussion Starter #33
Of course I can remove the engine without to have to cut the frame :)
and yes I can remove the valve cover with the engine in place inside the frame
small upgrade ... frame stiffening
adn relocation for the fuel pump and voltage regulator
Awesome Fabrication! (I'm sorry :D)
Unfortunately can't see the pictures on the first page, would you mind updating the links?
21 - 34 of 34 Posts
