If you're buying in the same year bracket you may as well get the 380 over the 300. The 2002 model will have USD forks compared to the 50mm RSU on the 1999. Only real big issue with the 380 in my mind is the bottom end costs a ton to rebuild if you ever have to have it done.
Other than that you can swap over newer forks, shocks, clutch, plastics, etc etc from different models and get a relatively nice more modern looking bike. If you have the money that is.
