hey i bought an ez electric wire kit from drc and it came with an on/off main switch that wires into the whole main harness. The old kill button wires into the cdi box and into the ignition coil. Does anyone know what the on off switch does? should i wire that in place of the old kill switch or just use both? maybe the one that came with the kit is to turn off the lights/switches functioning.... because i cant see how it would kill the bike being wired into the harness???
Just leave it be. I used a switch on my WR that had an on/off also, but kept my factory kill button. I just switched it to the throttle side of the bars. It was going to be more work than needed.
the kill switch usually grounds the power at the cdi box shutting down the motor but leaving power circuit open (if your ride has a battery the lights will stay on.)
the on/off switch kills the power alltogether
hope that helps.
sdmotard
