I know every bike or vehicle has common problems and or needs. It is a 08 610 sm. I wanna know anything you can help me out with. It already has leo vince full exhaust and o2 sensor delete.
I.E.:
-suspension settings (210 lbs)
-common problems (tsb car wise)
-rec. parts upgrades
Check the torque/torque the shit out of the primary gear nut in the right side case when you do your next oil change. It comes loose and the counterbalancer fails causing scary vibs. Mine came loose at 5k. On the fuell pump under the tank, see those 2 fittings, the red and white one. The break super easy, so when you take the tank off be very, very, very, very careful. Husky says if you break them you have to buy a whole new fuel pump, but there is fixes for it so you dont. On the left side of the engine block near the sprocket, there is little a cover for a oil filter with 2 bolts holing it on. That requires 2, and only 2 lbs of torque. They strip out super, super easy. Basically hand tighten and then another 1/4 turn. Oh and check the clutch cable. Some people say the snap.
