1 - 20 of 22 Posts
Discussion Starter · #2 ·
any one ???
I can't comment on that stuff, but I run 10WT fork oil in the Magura setup on my Husky and haven't had any issues with it.
Also you shouldn't have to bleed because the hydraulic clutch is a contained system.
i guess ill go to my local store and pick up some fork oil then thanks:)))
Fork oil works great. 5-10 weight range.
thanks i just called my shop and they have it in stock ... which is better 5 or 10 thanks
I had some 7.5, so that's what I used. I would go with 5 if you're going to buy it.
great thats what ill get , another thing is, do u have any idea why i lost clutch feel ???all i did was change the clutch ...but i did read some where that after changing the clutch u have to bleed the system but i couldnt find the link
again ..
Like Ash said, the hydraulics is a contained system down to the slave cylinder. If you never broke the system, something isn't right with the install. Push rod would be a place to look.
Another thing, these can fool you if the bike isn't running. If you haven't already done so, crank the bitch up and see what it does.
Discussion Starter · #13 ·
..i guess it did fool me then cause i didnt start it yet ...so with the bike off u wont feel anything ..i hope this is the case , after work im heading there through the storm to test it out :))
I lost clutch power all of a sudden on my SMC. Apparently it's common with the Magura systems. I had to change my slave cylinder O-ring, flushed new fluid and bleed, no problems since. When my clutch failed, I had lost fluid in the m/c resevoir and noticed bubbles in the fluid when I pulled the lever. The slave cylinders do vary by model.
I picked this fluid up at Carquest. It retails for close to $20. It's a full synthetic hydraulic / mineral oil for clutch and power steering systems on VW / Audi / Porsches. Figured if it was good enough for them, it was good enough for my KTM. :headscrat
Discussion Starter · #15 ·
i didnt know u can replace the o ring cause i just replace my old save a few months back ..good to know :)))))) i got fork oil weight 10 cause i couldnt find 5 weight :( nore 7.5 ,,,,
Discussion Starter · #17 ·
Any luck? Is the clutch working now?
not yet as my bike is about 40 min from where i live ( sucks to live in a city ) im gonna try and get to it tonight if its not raining again ....:((( but ill update when i have some news , good news i hope :)))
Discussion Starter · #18 ·
update that problem is fixed but i have another now ..
so i took every apart again , measured all disks and everything is in spec ..started bike worked fine for a min or 2 and then when the bike is not moving is hard to shift but when moving its fine ...what do u think is wrong???? ...i tightened the spring to spec 8nm
Discussion Starter · #20 ·
1 - 20 of 22 Posts
