1 - 8 of 8 Posts
I went and looked at it yestarday and im not sure if its something i should get. I wanted a CR500, but i suppose a KX is pritty similar. Its got farely new piston and rings apparently, but the head gasket is blown. I can kick it over with just my arm, and there isant a lota compression at all. And there was not only coolant seepage from the head but oil and gas to...?
It has no front or rear brake, rear drum is shot, and front needs a new master cylinder and fluid. Plastics and seat are shit but it is a 1989. What ya think, worth my time to fix up and tear around on? Maby someday make a Sumo out of it:hmmm:
http://nwct.craigslist.org/mcy/714999850.html
Its not an 89. 82 - 85? The KX line went to disc rear brakes in 86. The 89 was a great bike with the mombo 44mm front forks.
No compression......sure it has a new top end in it........run!
I agree, run away.
1 - 8 of 8 Posts
