1 - 9 of 9 Posts
Just bought Brakings 320mm rotor and POW83 relocation bracket for my stock caliper on my 06 CRF250R. How does the OEM caliper bolt up to the relocation bracket? Pictures would help! Thanks!
Sorry no pics but you have to take apart the stock caliper and swap the stock bracket with the aftermarket takes about 5 minutes.
kevin
the stock caliper pin needs taken off the stock bracket and blue locktited into the new one....15ft.lbs
actually we are both wrong...it's 16 ft lbs i just chgecked my pfd manual
Actually 69 I've got agree with our friend from APA. I don't use my torque wrench unless I'm working on an engine.For all else I use the feel in my palms.After 40yrs of wrenching I trust my hands.Aluminum? Blue Loctite and hand snug.
Thats a great reference site. The main thing that determines torque value is strength of fastener and material. If you are tightening into aluminum and it gets tighter tighter then looser, you just stripped the hole. That is one of the feels that gets aquired over the years. 16 ft/lbs is not very much, I agree, blue lock-tite and snug.
1 - 9 of 9 Posts
