The issue im having is i can not find a tuner anywhere near San Antonio. I am willing to send my ecu out in the mail if someone would set the base TPS and base maps. Any tuners or businesses that can do this? my MPG is horrible after my power up kit install. i know car tuner companies do this so a car doesn't have to be trailer-ed hundreds of miles for a software update on the ECU. Hopefully someone can point me in the right direction....:rolleyes2:
What year bike?
seriously no one has a suggestion?:rofl:
I would suggest a Power Commander III. Tune it yourself. The PC 4 and Auto tune work best with the 09's and up. Hope that helps.
Themotorcyclefactory in Woodbridge, Va has I beat
Hall's Cycles in Ill has it
Fast by Ferracci in Pa i am sure has it too.
-Check with them to see if you can send the ECU to them for tuning.......
This is all based on how I understand it and that may be off. The powerup kit puts the bike where it should be in terms of air fuel ratios. My stock bike with the o2 was so lean it barely ran. Emissions were a priority on this bike to husky. My suggestion if you want good mileage is to go back to an 02 sensor. If you flog the bike and want it to last, put up with the mileage decrease..
