3721 - 3740 of 3762 Posts
Beautiful! Who makes those fenders? Also does anyone know if the 2009 style number plates will bolt onto the 05-08 bikes? Everything else is the same I would like to update if possible
I got them from a guy out of Orlando named shawn, He had a company called composite art and could make anything. Since then he had closed up the doors and started working on airplanes I believe. Im pretty sure the number plate will work on your 08, I used to have an 08 and they were very similar.
KTM Front headlight/plate cut 1" off top. 17x5 rear Excel w/160/60-17 Michelin Pilot
That looks so much better then the husky head light! you got a link to where you purchased that set up so I can copy you!!!
Got it on eBay. Painted the bottom two corners flat black and cut 1" off the top (same angles). The bulb SUCKS!!! Might as well not even have one but I already had an HID conversion that mounted right in.
