I recently bought a motorcycle that didn’t start. After doing the normal check ups we discovered that the freewheel was worn out which caused the flywheel and stator te get damaged... Ive drained the oil but i am still affraid that there are still metal parts in the engine. Should i just do some more oil changes with short intervals or use some form of disolvend?
Yeah run oil changes in expanding intervals no need for disolvants etc.
1st in 30-40min running 2nd double that 3rd double on the second again and so on ,until you get to your normal change interval.
Start with a fresh oil filter and change that too if you see particles.
