So I was putting in a slipper clutch yesterday and when assembling everything back and buttoning up the bike I did something stupid. My air compressor hose was sitting on top of the clutch guiderod / pushrod so I didn't see it. So I get the bike all setup and pull the clutch and BANG! the slave cylinder detonates. Apparently I've gone and fcuked myself here and will need a new slave cylinder.
  • Anyone know the parts numbers of what I need to fix this?
  • Perhaps a husky parts manual in PDF I can download?
  • I recall that KTM uses the same clutch and slave on some of their bikes - can I get the parts to fix this from a KTM shop? If so, what do I need to buy?
Kicking myself here... I've done too much clutch work in the past to make this mistake! :rolleyes2:
halls cycles has the parts fiche on their website. The slave is different on Husky's vs. KTM. Also try Parts Unlimited.
If you just need the piston, get the 7602 racing piston. It helps a lot with some of the slave issues Husky's have. I have one in my 09 and it did help with the leaking/inconsistent feel mine had.
http://7602racing.com/prod_clutch_piston.php
How do I know if I just need the piston? I assumed that was all I needed because the housing section listed on item 32 looks like it's just the steel cover and housing. Perhaps I'm wrong. I have no idea here. :rolleyes:
Not sure, you might have just blown out the seal on the piston. Its a square o-ring that is usually a buck or 2 if you can find the size. I assume you have pulled the slave cover off and checked out whats damaged right?
