1 - 20 of 22 Posts
so i just installed my slipper and im having problems ..what did i do wrong ??
when i put the bike in gear it does not move ..????any ideas and the clutch has no feeling ...
sorry i have ktm 560 smr 06
no i did not check the thickness but thats on my to do list now
NOTE:
– All lining disks together should have a total thickness between 13.35
and 14.00 mm.
found this too
What brand of slipper clutch?
adler i followed these instructions but i installed the everything in place not like the book said in the vise first then in the bike ...do u think thats the problem or worn clutch thank u very much for helping btw:))
Discussion Starter · #13 ·
so maybe that first plate is wrong then ..ummmm why do i have it ...i guess ill try with a normal one ??
Discussion Starter · #17 ·
Discussion Starter · #18 ·
what page ???thaks
sorry found it, now i remember , i checked it ....darn ill open it up again and go over everything ...funny when i turn the clutch the bike moves but under the power of the motor it does not
Discussion Starter · #19 ·
update so i took every apart again , measured all disks and everything is in spec ..started bike worked fine for a min or 2 and then when the bike is not moving is hard to shift but when moving its fine ...what do u think is wrong???? ...i tightened the spring to spec 8nm
Discussion Starter · #20 ·
finished !!!running great :))))
1 - 20 of 22 Posts
