I am having trouble keeping the Z running. It stalls off idle like when you let it idle with the coke on too long. Extreem bog when I snap the throttle under load. This problem is new and sudden, I rode the bike in January on the 11th & 12th the temp was 10 plus degrees C and bike ran great. The only thing that I have done to it was install the cyclose head light blinker hand gaurds and integrated tail light??
Ideas..........???????PPPPPlease!!
Discussion Starter #2
hey would it be possible that I pinched the vac tube I have run up under my seat, have it there so I don't draw in water when running across water. would this cause the bike to stall out?? I'll check next time I'm down at the shop.
zzzzzzzzzzzzzzzzzzzzz. please omit this problem post, I am a dumb ass had run low on fuel, switch over to reserve and all is well. The first thing to look for is always the last place you look!!
cheers guys
