8761 - 8776 of 8776 Posts
So a little back on track here, you getting street wheels for it? What tires are you getting?
I finally pulled the trigger...
This weekend I ordered my dubn9ne's with black barrels, black nips, black spokes, and blue hubs.
17x3.5MC Front
17x4.25MC Rear
Searched for the distanzia and everything I found said they were replaced by the trailrider's, so that's what I ordered
120/70 Front
150/60 Rear
I got a 42t just because it was included with the wheels but I think I'll keep the 43t on Helo practice balance point... That little bit of torque will Helo.
There are a couple missing odds and ends.... I need the "X" fork guards to clear the sumo wheels and tires...I'll also need a new brake line and caliper. I think what I'll do for that is just convert my current setup, then just build the spare set on the side and bleed it then I can just swap everything that bolts to the forks in 20 mins
Will look like these, except the nips will be black
Sent from my LG-H932 using Tapatalk
Where did you order tires?
I got my last set from Rocky Mountain ATV/MC, but they don't offer the K73. Looking to get them from Cycle Gear.
Upgraded from my Drz. Got a Husqvarna 450 smr. Very good bike. Gonna check out the oahu FB group and link up with some riders. Looking for some carb tuning help and learning.
Picked up the bike on 3Jun2018
Stock
Current build, minus the tires as of last night, 11Jul2018... I took the Avon's off last night
Stock
Enjoy Kaena Point with a WR on Distanzias ona good day ! :bannana:
I haven't had distanzia since my last wr... This go around the distanzia weren't available, discontinued... They replaced with the trailriders, which I removed last night. Those are for sale, 50 feet on them, if interested... The 120/70r17 that used to fit the WRX now does now. Last time I had x wheels, this time I have dubn9ne's and the front is 0.5" wider than the x... Rubbed the forks... Perfectly offset wheels and properly inflated. I really wanted to run those tires. If I give them away for 200 maybe I'll lace a 3 inch wide barrel to my left over r hub so I can use the tires. They are great tires, I loved my distanzia in the harder compound...
Some cool stuff in the works
Going to a stand alone here shortly if I can't get rid an issue with the ejk. I have had 2 bikes, both with ejk, and both had cuts but in different spots.... I want to see how my ejk is doing with my WBo2 when I get it installed. After that I'll decide if I'm going to move to the next:
Full stand alone engine management
