Not sure about a full premade harness I'm sure there is a company outthere that'll make one but it won't be cheap.
These harneses aren't hard most of it's one power and a frame ground. Do you just not want to deal with wiring? No tools?
I have been slowly building mine up as I ride started with head and tail light brake switchs and then rectifier battery which you already have added horn and soon blinkers as I have the components just need time. Like I said it's a super easy hArness setup just one part of it at a time. For the handle bar switches don't even bother in the enduro aftermarket ones they are Chinese crap most likely to break whin installing. It's just as easy to use an e-bay oem bikes switches and way better quality. I used r6 switches they feel like a dream.
But if you decide on trying to find the premade kit good luck I think even most of those aren't plug and play all these bikes are different and too many variables. You allready said you have E-start so that's done as well as your battery rectifier all you need to do is add the lighting correct? Easy as pie. Good luck
Z
Z
