1 - 15 of 15 Posts
I found the stock to be a little lacking, so I stepped up to a 16T in the front and it helped a lot. RPM's dropped to a more comfortable level when cruising at 50-55. First gear is a little on the tall side now and would probably be a pain if I were doing any trail riding, but it is very manageable on the street.
stock is fine on mine. 14/42
My 510 was 14/42 stock and now I'm running 15/40 for the street and it is much better. I was afraid it would turn in to a sloth, but it's just a quick, all with an overdrive/cruise gear now for when the road gets straight. It will cruise at 80mph now as easily as it did before going 60mph. I also have 13/14 front and a 42 rear if need be to gear it back down some. All these sprocket combos work with the OEM length 106 link chain too.
I have a 13 and 15 tooth CS sprocket too. the 13/42 made 1st and 2nd gear useless on the street and 1st gear was useless for the track. I have to try the 15 tooth for the street.
Yes, 13/42 is offroad or cart track gearing. 14/42 was a decent compromise for all occasions. 15/40 is perfect road gearing, I have even done some light offroad with it. Anything below 10mph requires a bit of clutch work to keep momentum and avoid stalling. It will take off from a dead stop just fine though.
A 16t fit the front of a 450? chain didn't rub on the slave cylinder guard? my 09 doesn't look like it'll fit
Hmm... I'm thinking 15/45 or 14/42 for next season. I try to avoid straight highspeed roads as good as i can.
I have to buy new chain anyway, somehow 30% of my o-rings from stock chain have disappeared. No idea why....
depends on how big your streets are and how fast you intend on riding on them !!!
usually dropping one tooth on the front livens things up a bit if thats what you wanted to do
1 - 15 of 15 Posts
