I just put a Jardine full exhaust on last night and it runs good with the stock jetting.
Im just concerned about leaving it that way. Has anyone done a f/s on one of these? What kind of jetting should I do, if anything. I suppose I will pull the airbox screen and drill some holes in the airbox as well...thanks.
first off , think of the motor as a air/gas pump if you want to make more power , you need more gas , and more air , if the mods you make , didnt cause you to have to add more air or/and more fuel , you didnt make more power , so if you install say a pipe , and it didnt run like crap/ causing you/ to change the jetting you probably only made it louder.
thanks i understand that concept. all i am asking for here is if someone has a 150r and has gone through this process already...
i have added definitions to my acronyms for those of u (you) that are for u (you) acronym challenged.
i have an FMF (flying machine factory) fatty (large midsection, BBP) FS (full system) on my 150R (150 rockin'). i did rejet and it made a noticable diff (difference) in the midrange. so altho (although) the bike may seem to run good u (you) can fine tune it with the jetting. it helps to have a dyno (dynomometer) to do this.
don't drill holes in the box (airbox). i did and all i got was dirtier filters. there are 2 gaping slots in the side already. rem (remove) the screen tho (though) it is restrictive.
class dismissed and dissed.
haha nice. thanks for the info. what exactly did you do for the rejetting?
:laughingr:laughingr:laughingr:laughingr:Funny:
