2016 Husqvarna 701 Supermoto
  • Only 7k miles
  • $8400
This motorcycle is set up how it was supposed to come from the factory, with tons of bottom end power and better gearing making it a true supermoto. Over $4k invested. It has everything you’d ever need:
  • Rottweiler full air intake systeem + Power commander V with fueling and ignition timing map + o2 delete resulting in +25% HP
  • Akrapovic exhaust
  • 15-42 gearing
  • Seat Concepts comfort seat + black seat + stock seat
  • Lithium ion battery with power reserve for emergency start. Doesn’t go flat and saves 8lbs too
  • Rear wheel ABS disable dongle
  • Cyclops super bright LED headlight
  • Tail tidy, LED blinkers
  • Zeta hand guards
  • Engine skid plate
  • Front + rear axle sliders and exhaust slider installed, I also have RG engine mount sliders but currently not installed
  • Vanasche case saver and rear brake protector
  • Bar risers, but currently not installed
  • Ram mount mirrors for easy removal
  • USB port for phone charging or GPS
  • Rottweiler under seat bag
  • It’s had the 6k mile valve check service, so no need to worry about that
  • All original parts included
Clean title, no lien. Registration paid till May 2021. Not in a rush to sell. If the ad is up the bike is available.
155099
155100
155101
155102
