I'm trying to figure out which forks my Husky TC 450 has to help solve another issue. From what I understand I either have 45 mm forks or 50mm forks. Is the measurement taken on the outside diameter of the outer tube (the ones that go into the triple clamps on my inverted fork setup) or the inner tubes (chromed ones)? I put my micrometer on the inner tube and it said 45mm exactly, I put it on the outer tube and it said 52mm, seems clear cut but I am reading conflicting info doing searches. What is the answer here?
Nate
measure the sliders.. in your case 45mm
