My street bike is a 'oo yamaha 426. And it is louder than H E double hockey sticks. Currently it has the stock muffler,repacked with strand type packing. I can get a Q muffler brand new for $100 off retail . will it make a difference ? or should I make a small baffle for the inside of my stock muffler. I also do not want to loose any power ,as if that is not to much to ask for,to shut the thing up a little.
I have a '99 WR400 and have the FMF Q and the Pro Circuit R4 for it. The R4 is basically a straight pipe and is louder than hell with the Q being somewhat respectable. There is a slight power difference in the two with the R4 feeling like it accelerates just a tad bit faster.
If this is a street application then the Q is the way to go since the popo is going to hassle you if you are too loud. Plus on the street I don't think you would notice the power difference anyway. Since mine is for the track only I run the R4 and use the Q if I am going off roading somewhere where they check for noise.
Hope this helps.
Restricting the baffle will most likely cause power loss. You could check HMF, they had slipon mufflers for the YZ, and I'm pretty sure you could buy a Quiet Core for whatever exhaust you bought. They advertise their Quiet muffler to be pretty good noise reduction, without bad power loss. :hmmm:
The fella I purchased my bike from, said my HMF was considerably more quiet than whatever he was running. Not a shameless plug, just trying to send out options. :)
