Did you clear the codes like it says to do at 621 miles? I wonder if my local dealer can do that, even though they don't sell KTMs...i had a problem with my 690 and the light NEVER came on. take it to the dealer and have them hook it up to the computer. it'll tell all.
does it seem to run fine?
we had my bike hooked up to the computer a few times and it never had any codes saved. the computer never knew there was a problem.Did you clear the codes like it says to do at 621 miles? I wonder if my local dealer can do that, even though they don't sell KTMs...
Cool, thanks. Apparently the input signal from my throttle grip sensor is either too low/high.:thumbup:The fi light will only flash codes while in neutral or just after the boot up cycle... Wait until after the boot up cycle and count the flashes, look in the book and match up the code...
An' how do you fix it? Mine has the same "problem." Anyone know if it can harm the bike running with this issue?Cool, thanks. Apparently the input signal from my throttle grip sensor is either too low/high.:thumbup:
I took mine back to the dealer and had them fix it since it was still under warranty.An' how do you fix it? Mine has the same "problem." Anyone know if it can harm the bike running with this issue?
