So I went to adjust my tps on my 2016 exc 500 w the pigtails just as I’ve done several times before and was confused to see that I was getting a voltage reading no higher than 4.9 when adjusting it. Any ideas as to why this is happening and what that is indicative of would be greatly appreciated. Thanks boys
when you are checking your TPS shouldn't you be looking for a setting around 0.60? The bike should supply 5.0v to it but you should be checking for around 0.6v in the throttle closed position between 2 of the wires. I believe its the black and white wires that run back to the computer. If you check black/red i think that is where you are seeing 5v(roughly).
