Hi. My rieju mrt 125’s el start doesn’t work. Does anyone know what the problem could be? I tried changing the battery but that did nothing. Run-starting it works tho. Thanks
Try to heat the carb with a hairdryer and see if it helps, if its vacuum operated fuel valve tap, check if it works. Check if choke is working correctly.
Try to dry or change sparkplug, and check if the mybkexperience air filter isn't completely shit, dry the spark plug lead and cap.
Dad Bod Super Model
Check for a blown starter circuit fuse. It may not be in the fuse block - it might be an in line fuse closer to the starter solenoid.
