1 - 13 of 13 Posts
We just got done taking Dougs motor apart most of the way and to say the least not good. We can't get the rod out of the case!
At a shop I worked at years ago we had a half a rod that came out of a TT600 flattracker. The piston had broken at the end of the back straight and the rod sawed a big chunk out of the case and came out the front of the motor taking out the main frame down tube and making the bike impossible to steer. That's when the rider lost control and cartwheeled the whole thing. The story was that there wasn't much of anything left worth keeping other than the half of the connecting rod as a 'trophy'.:D
Got any idea where the failure started? did the rod break first or as a result of the piston breaking?
The failure was the rod and the piston didn't look too bad believe it or not. This is a very good example why you need to change your crank and rod periodically. Supermoto & Flat track your just plain riding the piss out of these bikes causing tons of fatigue on your motor parts.
wow......
Motor go BOOM!! That's awesome, haven't seen one blown up like that in awile.
Just drop it on the ground a few time, looks like it should split like a walnut. I have to say again, impressive meltdown.
Discussion Starter · #12 ·
Ok, I'll try that. I'm assuming it can't be damaged any more than it already is....:D
1 - 13 of 13 Posts
