I have had my front brake lock up three times now.. once was when it was just sitting went to move it front brake locked up.. hand brake is super tight.. bleed the brakes.. works fine.. does it again 2 hours later going down the road.. then 2 days later going down the road... just bleed the brake every time and then it works perfectly...
you think to much fuild? air in the line.. bad fluid? dirt in it?
just wondering what u think... i'm thinkin to much and bad dot4 fluid
ive heard that dot 4 will expand if you have too much, causing this. were you using them alot before it happened?
just a guess.
