Is that made by Acerbis as well? I've not seen those before, gorgeous either way!I've put these lights on my DR-Z, they are called Rage, bought them from a local supplier, cpst £30.00, about $60. I have them wired so that the outer lights are on all the time with the two central lights on if the flash button is pressed, or the main beam switch is on. The fixing was easy, using the bottom standard mount together with two brackets from the fitting kit supplied. Took about 10 minutes to install including wiring.
Looks like the Black Mamba on Motostano's site to me. Great, now I want one.That rage headlight looks almost identical to the Acerbis Diamond headlight. So if you like it, you can get it almost anywhere.
Hi missile, do you have a chance to put some pictures online on how you fixed this headlight ? I ordered it from Forrest, but having so trouble fixing it ... would be greatly appreciated !!!I've put these lights on my DR-Z, they are called Rage, bought them from a local supplier, cpst £30.00, about $60. I have them wired so that the outer lights are on all the time with the two central lights on if the flash button is pressed, or the main beam switch is on. The fixing was easy, using the bottom standard mount together with two brackets from the fitting kit supplied. Took about 10 minutes to install including wiring.
The lowbeam bulb went out (or broke) after a few rides. I am not shelling out $60 for a new assembly so was wondering does anyone know if the highbeam halo fits? It is $8.95 same wattage and I saw on another forum that it DID work, but no pics. I am running on highbeam right now to makeup for it as I have it wired for lowbeam being the round (right) and the small light in the flood side. High is ALL (but obviously without the blown round light atm)I have one and the diode mod only takes a few minutes and only cost a couple bucks. I like it far better than the stock, both for looks and weight reduction. I actually think it is better at night, but that is just me.
