whats up guys. i wanted to cut down the stock front fender on my drz and was wondering if there was a good way someone has used other than just simply breaking out the saw. if anyones got a tip or trick that would be cool.
Mask it off where you want to cut it. Draw the outline with a sharpie on the masking tape. Cut it as close to the outline as possible. Go back and file down or grind off the excess to get the perfect shape. Sand the edge with progressively finer sandpaper until you get a smooth edge. Peel off the masking tape.
The masking tape is to keep you from scuffing or scratching the shiny surface of the fender while working on it so you should use a couple go rounds with it.
