I took the LED brake light/blinkers off my FZ600 after I crashed that, and would like to install them on my WR450. I'm not sure how to wire this though. The bike has a Baja Dual sport kit. I'm planning on mounting it on the side plates like how it was on the FZ6.
Any ideas which wires go where?
Stoked to be back on a supermoto!
-Mike
You should be able to tuck them under the seat.
I had a dual sport kit on my WR. Now I just have a rear brake light.
I had two ebay led strips mounted on the left and right edges of my plate for a while, but they were crappy and dim and you could barely see them in daylight. Where did you get your led strips from and how do you find the brightness during the day?
As for wiring them up just trace the ends back to the strips to figure out which wires are for which light and wire them in parallel with whatever blinkers are there. LED's are directional so if they don't work check the polarity.
