1 - 8 of 8 Posts
G'day.
I have a 2010 CRF450X Motard for street use and recently purchased a Brembo front brake kit (13mm MC) from a member here, however the lever is longer than I am and I need a short lever to fit under the hand-guards.
I have searched online but it is like looking for a needle in a stack of needles...
Hopefully the combined wisdom of this forum can help me out. I also don't want to spend an arm and a leg if I could help it.
Any suggestions / links etc would be greatly appreciated.
Pic attached.
Cheers.
I literally Googled Brembo shorty lever and got loads of results.
Take your lever out, search around online until you find one that looks similar. Hope for the best.
Even better, find somewhere that sells new levers like ASVs or similar, order a few that look right and return them all when you know what you're looking for.
Either that or take a file to the one you have...
Agreed. You need to take the lever off and search around for what will fit. ASV makes shorty levers - and if you want to spend less, check eBay. I bought a pair of shortly levers for my GSXR off eBay and they worked like a charm.
Just cut the ball tip off the lever.
1 - 8 of 8 Posts
