I've had a search around here and the Google, but can't find what I need; specific help.
I have a CRF450R 2006, which I've just installed an "electrexworld" ignition and lighting stator, which with the OEM flywheel is rumored to give 70watt, revved up, power.
I'm in the process of building my own electrical loom but AC power is new to me and I just want some help from the pro's please? :headscrat
Inventory
Polisport MMX headlight - 12v 35w main, 4w side light.
Rear bulb tail light with license plate light.
4 x indicators - 21w bulbs.
1 x flasher relay for indicators.
1 x switch with lights hi/low, horn and indicators.
1 x 12v horn.
1 x 12v AC regulator.
10 meters 15 amp single cable.
Possible I'll add fuses in. (Necessary?)
Will the following work...
Stator > ac regulator > switch > lights?
I have two cables coming from the new stator, I guess I'd have to put both through the 1 x AC regulator? Or do I need 1 x AC regulator before each bulb?
I'm a bit confused with this, can someone help? :headscrat
Many thanks.
Inventory
1 x 12v horn.
Many thanks.
