Hey guys after two years ive finally pulled the trigger and ordered all the parts to finish my cr500 sumo project, the only problem is not one electrical part came with a wiring diagram and i am damn near clueless. Im running a complete 96 cr250 ignition on my 500, and am using the electrosport lighting stator and oem xr250 rectifier/regulator. Im just gunna list the wire colors if you know how they go please help me out. I can wire the DC system and lights and what not, i just basically need to know what wire goes where to make the bike run. I know one wire is for a kill switch and one goes to the coil, and there has to be some grounds in there otherwise i dont have a clue for the others.
92-96 CR250 Stator:
- Solid Yellow (believe to be AC power)
- Solid Light Blue
- Solid White
-2 wire plug-
A. Green / red stripe
B. Blue / yellow Stripe
XR 250 rectifier/regulator
- White / yellow stripe
- Solid Yellow
- Solid Pink
- Solid Green
1996 CR250 CDI (3 separate multi - wire bundles)
Bundle 1
-Black/yellow stripe
-Solid Green
Bundle 2
-Solid Green
Bundle 3
- Solid Brown
- Solid White
- Solid Blue
- 2 Wire Plug
A. Green / White stripe
B. Blue / Yellow stripe
Cr500 with Lights?
I'm really interested to know if you got your setup to work. I'm looking at the same thing, but have no way to know if the 96 CR250 electrical system will work out.
Keith
