You need to go to ktmtalk.com. There is an entire section dedicated to the minis and much discussion of the clutch.
How big are you? My son has one, he is 10. I really don't think these bikes are good for full grown adults, mostly due to the auto clutch mechanism. You can set the clutch up to hook sooner but you are really straining the hell out of the whole system if you are more than 80 pounds or so. Also, if you haven't done it yet...immediately drain the clutch fluid and replace it with 250ml of your preferred fluid. The manual calls for 150ml and this is not nearly enough. When it slips, it puts enormous heat into the engine and the bike will boil over. I use B&M Trick Shift in my son's bike with an additive called 2TwoCool. Both of these were recommended on KTMTalk. When I went up to 250cc the clutch immediately started to slip less and the bike stayed cooler.
The clutch is probably the biggest tuning item on the bike. It is almost like black magic with all of these different suggested washer stacks. I have not delved into it myself as my son does not race the bike yet, he just plays with it in the dirt. It looks pretty daunting to me, actually. I am already planning the move up to a bike with a traditional transmission for him, instead of going crazy trying to learn all of the ins and outs of the centrifugal system.
Mike
Mike
