when i am coming to a stop from say 30+mph, i pull in the clutch and downshift, however the gear selector only downshift so much and wont go into a lower gear unless i let out the clutch a tad and feel the trans slip into that gear, then pull in the clutch to downshift again correctly.....
i was thinking maybe the lever on my bars is out of adjustment and not grabbing the clutch enough?!?!?! any other thoughts or theroys?
How much play is in the cable? There should be about the thickness of a quarter of free play between the lever and the perch. My guess is you haver a lot more and need to tighten it up.
BTW....how many miles and what type of oil are you running?
