Well I am new to the supermoto's scene I bought a 04 crf 450r a couple of months ago and decided to check the valve clearance and came up with this,
intake clearance .102 mm - .16 spec clearance + .65 current shim = .592 shim needed
exhaust clearance .356 mm - .28 spec clearance + .88 current shim = .956 shim needed
looked at buying shims but the smallest I could find for crf's are 1.20 mm, double checked the current shim just to make sure i wasn't missing a mm but came up with the same measurement, I doing something wrong here?
if anyone could help it would be much appreciated thank you.
