Can anyone tell me a good chain size for a crf250x supermoto? I have the stock sprocket on front which i think is a 13(not sure) and a 49tooth on the rear. Thanks
just cut down the stocker to fit. pretty sure stock is 116 link.
I have heard that certain o/x ring chains are to wide and will cut into the case without a spacer so be aware of that.
last one i put on was a DID ERT2 works fine.
Thanks. I want to keep my stock chain length since I will be swapping back and forth from street to dirt. I want to buy a new non o-ring chain and was just wondering if you knew how many links I should have. Thanks
stock is probably gonna be to long for your sumo set up, have to take a few links out which would make switching back and forth with 1 chain a pita.
better off having one for each.
Im running a 520, O ring DID on my crf 250 sm and have no rubbing on the cases at all,
From what i can remember mine is 108 links.
Jake
