1 - 8 of 8 Posts
i tightened my chain and did it back up and the adjusters were even but one didnt sit on the little adjuster bump thing. i went for 1 ride and its as loose as it was before.... where did i go wrong?
Did you tighten down the lock nuts??
What do you mean by little adjuster bump thing?
yeh i tightened the nuts up. just where the tension indicator things sit on a little thing to show there position
Somehow I can't picture what your tensioning system looks like...Is it the conventional bolt/lock nut type???
Is your axle tightened down enough? How can the chain adjusters move when the axle is tightened down and the lock nuts are tightened?
yeah they are the snail type.. the one on the right side is not sitting right.
1 - 8 of 8 Posts
