I know it's simple, but what's the cause??? Between one start-up and the next on my crf450r I've developed float-bowl overflow.Carb is stock except for anF2Racing Fastcap(floatbowl Drain)and ScaryFast accellerator pump cover(Powershot) Ran fine after those installs-sat for 2 weeks.Now it pisses gas from the overflow.Floats stuck?Floats filled w/gas?Any help would be great.
Thanks for the tip.Went right to it and sure enough.It was actually stuck-pulled it out and there was a tiny bit of corrosion/deposit on the 4 edges of the valve.Buffed w/600grit wet or dry-presto,freed up.
