I just bought a 100mm Brembo radial caliper with the 4 pad set-up to replace my stock Beringer FTC caliper. I also picked up an iron Beringer 310mm rotor. The question is do I need a special pad for the iron rotor?
run the pads of your preference.
I run sintered pads on my cast iron rotor. in the long run it'll wear the rotor down a bit faster but braking power is incredible.
Thanks Skully:thumbup:
I'm running EBC extreme- less bite than the stock brembo's but at least I don't sound like a school bus coming to a stop.
