Hello guys .
Looking for the best Tracker support that can be used on the motorcycle.
I have once found something that you can use with google earth map, and if you set a
radius on one area and the bike moves outside that area you automaticly recive an SMS.
So if anyone is using some type of tracker device on their bike Please post some info, advice and so.
Best , places, brank, models and such...
Thank you verry much
Best regards Dee.
have a look at this: 10 Best Smallest GPS Tracker - Buying Guide 2020
You can easily find such a thing. Generally speaking, spytec is the most commonly recommended. I am using one of these models myself. Sufficient battery life is one of the biggest advantages it has. During my use, it rarely loses location data. Another recommendation is AMERICALOC, which has a longer battery life and needs to be improved in position accuracy.
