I use Motul RBF600 in everything.
Definitely not racing her. I just have 12K miles on the same fluid and am well overdue for a change. I've never changed brake fluid before and I'm honestly anticipating a curse-god-and-your-own-existence ordeal. That is, I don't want to have to do this often.*grin*are you racing? If not I would just fill with DOT 3 and change often. This bike isn't too heavy and doesn't have much power, not much chance of brake fade with decent fresh fluid and pads.
if you're going to recommend to change often you might as well run DOT4 or DOT 5.1.are you racing? If not I would just fill with DOT 3 and change often. This bike isn't too heavy and doesn't have much power, not much chance of brake fade with decent fresh fluid and pads.
+1I use Motul RBF600 in everything.
Very good idea!Great feedback, guys. Thanks a lot! I think I'll get ambitious and upgrade to stainless steel lines whilst I'm at it.
Delphi Lockheed Dot 5.1 is without silicone , that's what I use on my bikeGuys, does it matter what brand of DOT-4 brake fluid I go with? What are all of you using?
How hard is it? A monkey can do it! I am living proof.On another note, how difficult is it to change the brake pads up front? Probably a stupid question, but I've never replaced brake pads before so here goes: will I have to drain the brake fluid for the pad swap?
