Trying to legalize my 03 450r, I mounted the dualsport headlight kit. Once my stator ,batt, rectifier went into place I began to plug wires.It looked straight foward on paper but the stator conn. did'nt jive. Yellow/yellow :thumbup:white/white:thumbup:then it showed light/dark blue. Stock harness has blue but not solid witout stripes as described. The other problem is that bolth ends are male connections. So im sratching my head ,then notice or/wh wire set from headlight kit waiting to be hooked to stator:hmmm:.After trailtech stator wire count I have no spare leads. I was wondering if that white/ orange from the headlight needs to be t-tapped . I also noticed the baja light has a rectifier/batt mounted to the back side. I would think I can remove one?If anyone can make sense of this question,Please help.
