So I broke one of the pillar things where the clutch springs screw into. So I need to get a replacement clutch basket. The husky parts catalog only sells the basket + primary gear for $550. I just need the basket and don't want to spend that much. Anyone know of an aftermarket maker or a place to get a used one? I don't need the plates or springs or anything but the basket.
This is for a 2006 SMR450.
How did you break it?
Check ebay. The reason they sell them as a set is they are supposed to be a matched set. But some have had good luck mixing and matching. As long as you use the same basket as as you took out (Aluminum for aluminum, or steel for steel) You'll be fine. I would imagine you have the aluminum basket with the gear riveted to the back..
Check on FBF's ebay store for an AL basket:
http://cgi.ebay.com/ebaymotors/Husq...Accessories&hash=item5ad78c00c4#ht_795wt_1165
