Hi-- I rarely am on this site, but I figured that I'd get an answer here as opposed to anywhere else.
I've got a Fox shocked '05 KX65 that I use as a pit bike (haha!). I may be 'tarding it someday, but for now I ride it in the dirt.
The issue I'm having is that the rubber grommet on the stock pipe between the expansion chamber and silencer just barely rubs on the shock spring. I already tried to loosen the pipe mounts and adjust the pipe slightly, but when I tighten the bolts-- it rubs again. Is this a common problem? And is there a different pipe I could run (according to the dyno charts at M&M Racing-- the Pro Circuit is the best pipe for the 65) that would clear the shock spring? This is annoying, and any input would be helpful. --L*64
