Hi All
Just got a DRZ 400SM - the bike came with a HID Country brand HID front light-
One of the relays went bad so I am going to replace the kit and I was thinking
about using the Same kit to replace it -- $49--
The kit has Both the HI and Low beam on One bulb --I think when you switch
between HI and Low beam the bulb is moved back and forth to create the different beams- (Not sure exactly what happens for sure but something moves)
I have not been able to ride the bike at night yet so I am not sure how good the
beam pattern is- but it looked kind of Wide from what I remember seeing
on the garage wall before it broke --
I read on some other posts on Huskys that maybe the bulb housing (lens)
may need to be changed so that it will have the correct beam pattern --
The kit that it has now the wires are Way to Long so this makes me think
the kit was not well thought out and having a relay go south so quick makes me wonder if the quality is as good as it should be --
So my questions are is this brand a good one and am I going to have to change
the lens ??
Can Shine some light on this for me--Jay--
the lens ??
